The "bad" part is Fairchild 2N3904CBU or 2N3904CTA (the "C" suffix denotes that the pin-out has collector as the middle pin, which is wrong). Mouser does not show a PNP version of these.
Originally Posted by Sathimas /img/forum/go_quote.gif What part number do you mean?
Order number at mouser or the number on the part itself?
Anyway, I'll look that up on Monday, I'm not at home this weekend.
Would be nice if the thing you discribe would be responsible for the error.
(Because it wouldn't be my fault then
Well I'm not sure about the 2N3906, but if you look up 2N3904CTA, you'll see that the item description mentions that the collector is middle pin, but it links to the same datasheet as the other ones so it's very misleading. Look at your order to see if you got the CTA version.
