Koobers
- Oct 16, 2011
I've always used iOS products and I have used the FiiO E11 with an FiiO L9 LOD until the iPhone 5, at which time I added the Apple 30-pin to lightning adaptor to power a pair of B&W P7, or AKG K550. What I thought this was doing was bypassing Apple's internal EQ and taking the audio down to a flat signal and then using the headphone amp to boost the volume where I could listen to the music as the artists intended. Am I completely misunderstanding how this whole thing works or is that an accurate representation of what's happening?
I ordered an iPhone 7 and I had wanted to continue using this setup but I wanted to upgrade the FiiO E11 to a little bit nicer unit like the FiiO E12. In researching a new amp, I am finding that 1. the headphones I own are low-impedance and shouldn't really need an amp to power them. 2. when anyone brings up the iPhone 7, they seem to mention using an amp with a DAC. So that's what is causing me to think that I have been misunderstanding this whole thing from the very beginning.
So I guess my question would be, how do I get the most out of my B&W P7 and AKG K550 on my iPhone 7? Is it possible to bypass Apple's post processing to hear the music the way it was intended and if so, do I still need an amp or DAC to do that?
Any help would be greatly appreciated. Also, if I'm posting this in the wrong area, please let me know where it should go.
