Originally Posted by jagorev
I haven't seen any headphone company that matches Sennheiser's build quality. They're usually built like tanks.
Originally Posted by db597
It's mainly the foam that's decayed - both the ear pads and also the pads along the headband. Also, the plastic does get worn out for the adjustable headband. My wife always adjusts the headphones when she wears them. Then when I put them back on, I adjust them again. After a year of adjustments, the settings get very "loose". It just doesn't click into place anymore. Also, I had the plastic headband of one of my Sennheisers snap while it was in my rucksack.
While I am not an exclusive fanboy for every Sennheiser model on sound quality, I would have to agree with jagorev in this case.
There is a fine line between robustness and
weight on your head. Sennheiser balances on that line better than most. The longest lasting phones I've seen in 30+ years of buying phones are the original Koss Pro4 AA's. However, they weigh as much as a tank. It's only the desire for longevity and that heritage that still makes them marketable today.
Foam will wear out in every case - period. I've had it do everything from turn into dust, to dissolving into a inky-goo (the worst) when it reacted with adhesive backing. For long term use, I would even study the construction of phones when contemplating a new purchase. If foam with adhesive backing is used anywhere in the construction, then stay away from it.
Pleather is the worst, but in most cases - easily replaced. It's not just comfort that motivates professionals to exchange Beyer velour cushions for the original equipment pleather on Sony V6's. It will flake, dissolve and stain in only 2-3 years in some cases.
All that said, Sennheiser's quality is just about the best. I don't know if the support is there, though. Ultimately, imports may not have the infrastructure in this hemisphere to offer something like the Koss guarantee. If longevity is your desire, then Koss's phones are the best bet, simply because of the guarantee. Paradoxically, though, their build quality is not among the best. Seems like car companies did the same thing a couple of decades ago - until they got the quality initiatives going in the factories, they increased the warranties instead. Koss is nowhere near that bad, though, and some of the phones have incredible sound quality for the overall package investment (KSC75's!!!).
