Rescue Toaster
- Sep 30, 2005
I've been fiddling with the design and I may even be able to get my tube amp back to single-ended. The problem was I return the transformer primary to the cathode of the tube, not ground. Along with the CCS feeds, this essentially makes the tubes run fixed bias, and eliminates the need for a bypass capacitor.
Since they're operating fixed bias there shouldn't be much of a problem with using a shared cathode resistor, assuming the two tubes are pretty close bias-wise (less than 10 volts difference on the anodes and I'd be happy).
Of course... eventually I want to try a real push-pull differential mosfet amp, but I can wire up this guy without chopping up my stock cable for the moment.
