Predator88
- Jul 8, 2005
Ok I am buying a new amp (portable or not it doesn't matter as I plan to try my hand at some DIYs in the fall). Anyways, I have Alessandro MS1s and listen to mostly rock, and I love bass. I have the ability to buy a pimeta for $80 from the FS forum, or I coudl go for a Z-audio epsilon, or the the electric avenues pocket amp. I've heard great things about the pimeta but how would it compare to the other two? Like would it be that much better than the epsilon? Or would the epsilon be sort of comparable but also then portable. I've opted against getting a cmoy as I'm goign to build one just for the heck of it later on for portable use so like i said, i can live without portability as the MS1s sound decent out of my mp3 player and I listen mostly at my computer anyways. ***Edit*** or should I maybe look into the little dot II (or II depending on when it comes out) or the little dot micro one that is supposed to be fairly cheap. I'd assume the other 4 are better than the micro but have no clue on how the tubes on the LDII would sound as I've never tried a tube amp.
