ramachandra
- Jan 5, 2012
Some of my thoughts:
The first thing you should do is to check the voltages when the system is off and when it is on. You need to find +18V and -18V and +8V in the D-Sub connector. Probably you find no +18V and the reg and the surrounding components need to be replaced.
Let the system run for couple of minutes and unplug it from the socket, and try to touch and find hot components. If there is a short circuit the energy converted to heat somewhere. Can be an OpAmp failed in short.
About the wire you found. It is probably created a short circuit to the ground, so it is possible your Sub not worked properly since the beginning. In theory the TDA amp maybe failed due to the constant connection to the ground, the built in short circuit protection reached the limit to take. If the amp have some sort of short circuit inside that can cause voltage drop so maybe enough to interfere with the requirements of the other components or even ruin them. For example the negative voltage regulator or the chip to turn on the system.
