- Jun 22, 2001
Yup. Most DC coupled amp makers use a DC servo circuit that basically nulls out and DC componant (and AC up to maybe 5 Hz.
Also, good headphone amps have a high damping factor that causes the driver to move only with the music and not rattle around under it's own inertia.
Assuming you are listening at less than ear bleed levels (and you shouldn't listen at any where near those levels) the premis of this whole thread is just wrong. If you do listen at very high levels you are LESS likely to damage your cans with a good amp as it is doing a better job of keeping the drivers under control.
Originally Posted by Hirsch A direct-coupled design needs to be well-executed to prevent DC leakage from frying a driver. |
