iNcontroL
- May 17, 2013
Hey everyone,
I currently own a high end computer system, primarily used for gaming. I also have a XBR65X900A mounted on my bedroom wall right next to it. I typically listen to music through my Sennheiser HD598 with Magni Amp hooked up to my Titanium HD. It sounds amazing, which unfortunately makes the speakers on my TV sound terrible. As of now I have my TV hooked up to my computer as well and typically just change my playback device to use the TV speakers when I wanna sit back and relax.
Now I've been itching to upgrade something and figured I'd upgrade my computer speakers, I currently have the Klipsch ProMedia 2.1, which I honestly haven't used in years preferring my headphones. Now I wanna upgrade to a system I can use both with my computer and my TV, I also wouldn't mind being able to lay down and listen to music from my iPod with Bluetooth. Unfortunately I'm limited by the size of my room. It's pretty small at 14 x 10 feet.
My current budget is around 500, I don't care whether it's a Home Theater in a Box, Speakers, Studio Monitors, or a Sound Bar. I just want the best sound for the size of my room.
As of now I've been pretty close to pulling the trigger on a pair of Emotiva Airmotiv 5s with Control Freak for Volume Control and the Emotiva BTM-1 so I can use my iPod Wireless. Another wall I've run into is that from what I read studio monitor's require an exact positioning, and I really don't have the space required to put them on my desk. I currently have my two 27" Monitors Mounted on one wall over my desk and the 65" mounted on the other well over my desk. The only way I can get around this is to also mount the speakers. I don't mind doing that and would buy the Emotiva ASM Brackets to do it, but now I'm not sure if I should mount them to the left and right of my computer monitors or my TV... I read they were great speakers for a desktop, but I don't know if they'll work just as well with a TV and how much position matters. I'm leaning towards mounting them on the sides of my TV because I'd use my headphones 95% of the time when gaming on my computer, so they'd probably get more use for music and watching movies, which won't really be done while sitting at the computer.
All in all, I'd like your advise on whether this would be the best route, or if there's anything better I could spend my money on sound-wise. As of now with the brackets and all the add-ons, this would run me at exactly 507 dollars, and I want to make sure I'm getting the most for my money.
Any help or opinion is really appreciated!
