Inspired from another user who also puts fo.Q TA-102 absorption polymer material on the back of his isolation caps, I went ahead with a try too. I have a mix of
gold plated brass and
rhodium plated brass(<-- link) RCA caps from Amazon which also show as Monosaudio brand. As I gather the concept here is to be a poor conductor in order to isolate or shield said sockets. I found this combination to sound best in my system, both types sounding different, and some plugs sounding better without. I also got a hollow
steel hole punch set recommended here, so I can make circular cut-outs of this effective and space quality TA-102 & the thinner TA-32 stuff that's imported from Japan off eBay.
It actually wasn't recommended to use it on these particular caps which have such a small cap cover, but I found it makes a good difference! Sound is more well rounded and organic to me. It sounded better on about 1/2 of the caps but not when overdoing it.
not the best photo and just my temporary amp, but it shows the absorption material on about half of the caps, along with the hole punch set I was holding.
Speaking of not overdoing things, I realized that some of the brightness was gradually creeping in after several hours of system usage was caused by excess usage of silver Faraday Fabric Tape on the ends of various cables. Use this sparingly because this along with TA-102 are very effective. I have found another great placement however for the silver tape on the outside of yet another component (long strips of it on my DC LPS, along with DDC, under DAC, all sides of amp, all sides of power conditioner but not on my grounding box).
