Update on the Aliexpress graphite powder and mixing with Tourmaline mixes and Magnetite by itself or mixes. Also the mix I am using for these ground boxes.
The graphite does what I mentioned before, and is definitely for the money worth it. Works mixed with either Tourmaline and Magnetite mixes. Basically adds a bit more micro resolution, quieter background, even more improvement to timbre, and a bit more air and refinement to top end. Gives a "feel" of beauty and delicacy to instrumental notes, mid frequencies and up, extremely hard to put into words. This is for the entire frequency spectrum.
Very little is needed for a 3kg - 4kg mix. In one of the pics with the graphite bottle is also a white plastic spoon. With amp Tourmaline mix, 4 small heaping spoon full of graphite. I am adding while I am listening. With the DAC Magnetite mixes, 2 spoon full. Any more than just mentioned and the system tonality changes. Adding more than noted the system starts to get brighter and leaner starting at the mids on up. This is why I started experimenting by adding addition Magnetite mass by chaining to another approx. 1.5kg of Magnetite and that balances and as crazy as it sounds improved tonality balance.
Here are the ingredients I have in the two types of ground boxes I made, specifically for the amp and DAC. Have not experimented with the Magnetite mixes on the PC and Router/Modem yet. All of these ground boxes are for "signal ground filtering", have not tried AC ground yet. I mention "about" because I added and adjusted amounts while tuning across time:
All boxes are the same purchased from Amazon. Internal wood mated seams reinforced with E6000. No copper shielding except on the ground box attached to the Router/Modem. The amp and DAC ground box do not like any shielding or large copper plates inside the box, degrades performance.
https://www.amazon.com/gp/product/B08P2N1922/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
All binding posts are pure copper from Aliexpress
Footers used are the .75" Platinum domes from Amazon
https://www.amazon.com/gp/product/B075KK8WXM/ref=ppx_yo_dt_b_asin_title_o00_s01?ie=UTF8&psc=1
Jotunheim 2 amp ground box: Main ingredient is Tourmaline
- Tourmaline chips - AA+ grade (eBay), about 3 lbs
- Tourmaline - Brazilian black Tourmaline powder (eBay), about 0.6 lbs
- Natural Shungite rough chips sized 5mm - 15mm (eBay), about 0.25 lbs
- Sodium Tartrate (Rochelle Salt) eBay - 0.3 lbs
- Silver plated 12ga. copper 5", just placed inside mix. (Aliexpress) I wanted to hear what silver does to the mix. May still add more later.
- Pure Rock Salt (Morton Pure and Natural purchased at Home Depot) - about 2 lbs
- Military Grade Graphite Powder (Aliexpress) - 4 plastic spoon full
- Pure Tungsten, sand sized (Aliexpress) - about 30 grams
Proceed DAP (older NOS R2R DAC)
ground box x2, one is for digital output and one for analog output
: Main ingredient is Magnetite
- Magnetite, High purity sand (eBay), about 7.25 lbs
- Silver plated 12ga. copper fine cut up pieces from 24" length or so wire. (Aliexpress)
- Pure Rock Salt (Morton Pure and Natural purchased at Home Depot) - about 1 lb
- Military Grade Graphite Powder (Aliexpress) - 2 plastic spoon full
- Pure Tungsten, sand sized (Aliexpress) - about 35 grams
Before the ground boxes were added, this system was already highly tweaked, and sounded fantastic. With these ground boxes, system sounds absolutely stunning. Literally an entirely different performance level. Anyhoos, just wanted to share the mix I am using as I mentioned previously I would. Hopefully someone will benefit or save them time if they want to go this path.
