cdacosta
Here is an update with experimenting on ground boxes:
* The audible effect of changing the wire only is very similar to changing the interconnect used for that component. This seems illogical but is what I am consistently experiencing.
* The effect of using ground box on router or in my case router/modem combo filtering the ground lead only on an open port dramatically effects performance.
* With a component such as a DAC with open digital and analog input or output ports, both digital and analog can be filtered. But must be with two separate grounding boxes for optimal performance. Filtering digital and analog with the same device sounds wrong or off.
* With changes such as mix of minerals or ground lead (wire and connection) takes a few days to fully develop. Initial understanding of how it sounds will be known within 10 mins to 3 hours.
* Box built like the one I recently showed, does produce a more profound effect vs jimmy rigged ( just taking a 5" or so lead and placing in a bag of the same minerals).
