wankski
- May 24, 2009
hey kids,
pretty keen to get onto a USB DAC for my laptop which is just using onboard s/c...
anyone know the difference b/w the alien dac and the hotaudio dac destroyer?
from what i can tell the alien uses pcm 2702, whereas the hotaudio gets the 2705 or 2704.... what do these numbers really mean?
trawling thru the site, apparently the 2702 has a higher SNR ratio and i assume its better as the higher end hot audio offering also uses it (much more expensive)...
any words of wisdom?
the alien is only marginally cheaper, but i should be able to build it ok, i'll get the pcm pre-soldered and do the rest myself.
thanks
joe
thanks
joe
