mrarroyo
- Jul 27, 2005
TheSoviet, before you do anything I suggest you remove the pads and wash them with liquid soap and lukewarm water. Rinse and repeat. The allow to air dry overnight, you will find the ear-pads will be softer and way more comfortable. Good luck.
