CookieFactory
Banned
- Mar 15, 2005
First off the iPod will take longer to load an ALAC file than an AAC 320. The difference in time is not insignificant, so that could have cued you off.
Secondly, and more importantly, you failed to volume match. Take a look:
Using the latest iTunes, I ripped a track 5 times using various AAC bit rates and one ALAC. Running it through MP3Gain you can see there are volume differences inherent to the track depending on what bitrate you rip at. The higher the bitrate, the higher the volume, or so it seems from this small sample. I'm unable to MP3Gain an ALAC track, but following the general trend, it would probably be 96.7+ dB.
Obviously in the general sense, more volume == more detail, soundstage, etc.
Originally Posted by unkoman richard, First I emptied my ipod. Then I ripped songs that I'm really familiar with(probably listened to them over 100 times) to ALAC, AAC 320, and AAC VBR 256. I named the songs with random numbers and letters so that I can't tell which files are which, and loaded them into my pod. Then I shuffled the songs. I wrote down my guesses on a paper and checked back on my computer to see which files were which. After several hours of this testing, the difference between AAC and ALAC became very apparent to my ears. I used well recorded classical musics and my favorite rock songs. Even with hard metal rock songs, the difference in sound staging was pretty apparent. Funny thing, it was easier for me to tell the difference btw the files using my e4 than hd595. |
