Happy Camper
Falling asleep with the K701s I do a lot. I dropped north of $2k for my amp though. Not saying you need that much but you do need a strong power supply that provides enough juice to handle the Ks. I use the worst option for them, an OTL design. I like the sound of OTL amps. Your best value is a SS amp. If you want tube sound, you can get a tube output dac to use with a SS amp. The couple hundred dollar hybrids don't have the power to do what the Ks are capable of. Yes they will sound nice, but won't grab the little f'ers and make them scream.
As far as bass, I do like the Ks bass but have rolled many a tube to find it. I don't like boomy bass but accurate, defined bass. The Ks will give you that. You will need to put use on the pads for the bass to finally start to shape up. New, they sound like crap. Part of the long break in of these headphones are getting the pads to compress and form to your head.
(looks around for olblueyez)
You really should try and attend a meet or two to hear what amps can provide. As hard times have hit, many are getting a lot less for resale. You can get amps for 30-40 cents on the dollar used. Not a good investment for return so get a good one that you can live with. That's what I've done and not regretted it two and a half years later.
Oh, if you are going to use a pdp/ipod, get a LOD for the best sound. While you can use the headphone out to feed your amp, it won't sound as good as the line out signal with a good amp.
Good luck with your quest.
