phah0124
- Dec 30, 2011
So I'm new to head-fi and just ordered my q701s from Amazon. I did a lot of research and am pretty confident that they best fit my style in both aesthetics and sound. I'm having a huge problem deciding what amp and DAC I should get though. I would be listening from my desktop, which has a dedicated sound card, my Macbook, and my iPod. I would be using these mostly for music and movies, but also a little gaming. I want to keep it under $300 for the amp and don't even know if I need a DAC. If I do, I'd like to keep that under $200.
After doing some poking around on the forum, I've thought up some combinations but have no idea if they would work or not. I would like to have a portable amp/DAC combo be the DAC and then a separate amp to actually power these cans. I don't know whether to be a cheapy and just go with the FiiO E7/E9 combo, or go with a different portable amp/DAC like Total Bithead and pair it with a Matrix M-stage or a Schiit Asgard. Any suggestions? Would I even be able to use a portable amp/DAC combo with a bigger amp so that I have a lot of power with my desktop, but can still use an amp on the go with my Macbook?
