477621
- Jun 6, 2017
Sorry for bumping an old thread. I am a long time lurker but only just got around to joining.
I just got the K7XX myself a couple of weeks ago in a new and sealed eBay deal for £116, I am very impressed with them. I also have the DT990 Pro but they were with a friend for a few years and I only got them back recently. I love both sets of phones for different reasons. I think I will end up selling off my now redundant AKG K550 and keeping the DT990 and K7XX. I am running them both from my LG V20 and find the output brilliant. Playing a combo of FLAC and Spotify Extreme. Certainly the V20 output is good enough for the likes of me. Hehe.
A couple of years on, how are you finding the K7XX? I'm struggling to imagine how much better they could sound post break in, did you notice much of a change?
Need help choosing guys. This will be my first set of expensive cans.
AKG K7XX Massdrop Limited Edition $200
Description taken from the massdrop page:
Massdrop x AKG
In 2012, AKG released the 65th anniversary edition of their K702 to instant acclaim. Built with a bass boost, improved comfort, and matched transducers, the limited edition K702 became a legend in the audiophile community for its sound and build quality. Following the success of the Q701 drop in June, we asked AKG if we could configure our own edition of the K702 65th, and they agreed based on their faith in the Massdrop community. Configured by Massdrop, manufactured by AKG, and made possible by you, the AKG K7XX Massdrop Limited Edition Headphones bring you rare sound at an even rarer price.
Matched Response
Using the same dynamic driver technology as the K702 65th Anniversary Edition, the open back headphones have been tweaked to deliver an extended frequency response and a wide, locationally specific soundstage that puts you closer to the source than most cans. The highs were boosted by an innovative flat-wire voice coil, the mids were brought up to better balance the range, and the lows were jacked up by 3 dB for fully immersive sound imaging. To make sure that the channels are synced up and well-balanced, each transducer is individually tested and paired to a transducer with the closest possible sound signature. To see just how well the channels match, look at the below graph featuring an overlay of each driver's frequency response.
Well Put Together
Built with your comfort in mind, the adjustable leather headband and memory foam earpads can be worn for hours at a time without fatigue. AKG removed the bumps that come standard on their headbands, giving you a fully smooth surface. Completing the package, the nearly 10’ cable is detachable and can be easily replaced if the need arises.
Specs
- Configured by Massdrop
- Manufactured by AKG
- Open-back construction
- Pre-selected dynamic transducers
- Flat-wire voice coil
- Varimotion two-layer diaphragm
- Genuine leather headband
- Memory foam earpads with velour covering
- Individually tested and numbered
- Detachable 9.8 ft (3 m) straight cable with 1/8 in (3.5 mm) jack
- Frequency response: 10 to 39,800 Hz
- Sensitivity: 105 dB/V
- Maximum input power: 200 mW
- Rated impedance: 62 Ohms
- 8.3 oz (235 g)
I do plan on buying a magni 2 amp and will eventually need to buy a modi 2 for a DAC. So powering these 62 Ohm cans shouldn't be a problem. But is it worth the 200 compared to picking up a set of 990's 250 ohm used for half the price. I listen to all types of music and plan on using these for gaming as well. Thoughts? Suggestions?
Thanks guys.
