boomy3555
- Sep 26, 2008
The last 702 cable I made was with the larger cable. It just takes more time to do the small work. The cable build is the same for both sizes, It's just a smaller diameter. IMHO, as the length is usualy under 3 meters for a headphone cable, the smaller diameter cable would represent no significant audible difference so I would start with that and see if it even makes a difference for you before attempting the larger cable.
