silvesnake
Now that you have a properly working pair of K371s, how do you think they compare to the MSR7B?
Sorry for my late response.
Firstly I would like to compare the sound signatures of both K371 & MSR7B
K371 - Balanced tilting slightly towards mid centric and slightly hollow sounding mid bass.
MSR7B - as everybody says leaner, brighter a bit of emphasis on upper mids and slightly recessed lower mids.
Both headphones have good extension either ends but different in presentation
Resolution:
MSR7B is a level above K371 in terms of resolution - Bass has very good definition and speed, Highs are very well extended and very well resolved to give an example the striking of drum stick to high hats and the decay of high hats are very clear in MSR7B
Soundstage & imaging:
MSR7B is a clear winner - It has better depth & width with very good imaging and definitely. K371 always sounds like inside the head kind of presentation.
MSR7B also benefits from balanced source - in terms soundstage dimensions and bit tighter bass.
