Originally Posted by apotek
anyways..i still would like to know more about akg's bass quality...I still don't now..if this can has bass at all???or what kind of bass????I mean I can buy a900 i have the money...but I wanna buy something good in a long run..and akg's that I found is alot less then ath's....so we will see I guess....
I honestly have no idea what more I can say. I've already put two lengthy posts on this single topic, and I don't think there's anything more I can do for you. Have you read my two posts above? I thought I explained it quite clearly as possible, but if not, I really don't know what to say other than somehow getting your hands on a pair and listening to them yourself.
To put it simply: these cans don't have too much bass. It's clean and it's deep and I find it to be very smooth as well. I don't listen to any music that requires too much bass (I sorely dislike hiphop/rap) and if I'm listening to any electronic music, I tend to just use my speakers for the all around effect. I usually listen to more melodic metal, so I'm more into the guitars and such, although drums are quite important, the bass isn't all that important for me. If you like bass in the background, more there because it needs to be rather than upfront and in your face, these are some good cans to look at.
To be honest though, you just can't keep asking what the bass is like on these cans. I searched far and wide on these forums and got the same answer that I'm giving you, so I ended up just whipping out some cash, buying the suckers, and listening for myself. I, unlike many others, was pleasantly pleased with the phones, so I opted to keep them. And considering that you're in New York (City?), there should be a place where you can try them out, we don't have too much of that in Minnesota, and I don't have enough time to go into Chicago all that often when I'm at school, so I tend to just buy them and try them. Best way to go I think.
