Originally posted by hero zero
The AKG K240S will sound good out of low impedence equipment such as portables and soundcards [if you're talking about the 55 ohm version...there's also a high impedence version out there, just like there's a 300 ohm version of the Senn HD280]
I can't really give a comparison for sound between the HFI-550 and the K240S.....sorry about that, but I'm guessing the K240S would sound better in most cases [if listening to pop music or rock and gaming]...it's also more comfortable than the closed Ultrasones.
Hope that helps |
I can't really say anything about the comfort of the other cans mentioned but my Trackmasters are very comfy on my ears and only need to be taken off about each couple hours for a short period of time. With the band properly adjusted, they fit like a glove. I've only had them for about 2-3 days too, so I'm certain once the headband stretches a bit more they'll be more comfortable.
I'm hesitant to comment on the sound of them, as I haven't had time to really 'burn them in' yet, which I usually just listen to a lot of music anyhow, and am a firm believer in the 'let them burn themselves in while I enjoy them' method. So far though, they've been excellent, showing no real attenuation at any frequency that I can notice and no real excessive boost in any frequency.
They do seem rather revealing. I can hear the differences between my lower quality ogg's and my higher quality (256kbps) ogg's rather clearly. The same can be said for mp3's, albeit I could notice that before-hand. It seems the soundstage was only apparent before. Now I can actually pin-point missing frequencies.
I'm not going to say they're absolutely the highest of reference quality, but they seem to be quite close enough for my tastes.
My suggestion would be to save up for some Trackmasters. They're not significantly more than the 550's. Some have said they sound too analytical and/or too bright. I don't really think that's the case though, I've listened to them right up to going to sleep since I've gotten them. They even follow me when I leave my house with my Karma.
I can't provide any back to back comparisons but I will make those couple of comments. I hope that helps the poster.
