AirPods Pro 2 vs Shure SE535
Jan 16, 2023 at 2:56 AM Thread Starter Post #1 of 2
frnziii
Germany
Hello,
I own the Shure SE535 paired with the FiiO Utws5 to go fully wireless.
Unfortunately, I’m not very happy with that combination. There is a notable hiss at higher tones wich sound almost some kind of overdriven and very sharp. Also they are not very comfortable. Neither the Shure (which seem to be bigger than the 215 and 425 I owned before) nor the Utws5.
Though I’m using Shure IE for more than a decade now, I’m considering to replace them with the AirPods Pro gen 2.
Would that be a good idea?
Jan 16, 2023 at 5:12 AM Post #2 of 2
I'm a big fan of the Sennheiser Momentum ear buds and had the v1 and v2, the v3 is the current version. Mids are on point and bass is well defined. Treble isn't harsh, but it's not subdued like on some of their headphones. I've given a pair as gifts to 3 of my relatives and even a year later I get emails that they still use them every day. I'd just make sure to buy direct from Sennheiser, not some reseller on Amazon because fakes are all over the place. Also if it's just Joe reseller, you won't have a warranty if it's not from an authorized dealer (like Best Buy, etc).
