dBel84
Cavalli Tinkerer at large
- Aug 5, 2006
hope it works as planned, post a few pics too..dB
Originally Posted by dBel84 /img/forum/go_quote.gif just pulled up tubecad to get a visual of what you're talking about - sounds like you are hooking up the 12V SLA's in parallel to give you ....12V , try putting them in series : + from SLA 1 to J4, - from SLA1 to + of SLA2 and - of SLA2 to centre tab between J4 & J5. Make sure yuo are getting the 24 + V from the ends of the series batteries before hooking it up - you should be good to go..dB |
Originally Posted by dBel84 /img/forum/go_quote.gif I am having a hard time trying to visualize the jumpers without seeing the pcb. The H+ H- should not be jumpered. J5 is what is not clear at the moment - does J5 connect to H+? if so then make sure that you connect the batteries to J4 and the pin between J4 and J5. How are you measuring the heater voltage - the best way would be as indicated on Broskie's web page - With the negative probe on gnd (centre point between J4 - J5) measure J2 = 18V, J3 Right = 12V, J3 left = 6V , J1 = 12V . I hope this makes sense to you..dB |
Originally Posted by dBel84 /img/forum/go_quote.gif I sure hope those bare copper wires on the input/output have some form of invisible coating to prevent the input/output shorting to ground. I would strongly recommend teflon coated or shielded wire. |
Originally Posted by dBel84 /img/forum/go_quote.gif The only other thing that seems to be unusual is that your tube shields are not grounded - if I am reading the pcb correctly, you have added a star grounded the star ground. It would be neater and simpler to merely use a jumper across C3/C4 etc. |
Originally Posted by dBel84 /img/forum/go_quote.gif why not remove the input output leads from the amp board and measure again. You should note that because the heaters are hooked up in series, the current flows as follows pin4->5 V3 - pin 5->4 V4 - pin 5->4 V1 - pin 5->4 V2 - refer back to Broskie's diagram..dB H- connects to J5 - my mistake |
Originally Posted by dBel84 /img/forum/go_quote.gif I think Andrew meant to jumper the Cap traces as they connect to ground, but either way works - I was thinking more along the lines that you may have connected the ground side to ground and not the side that connects to pin 9? ..dB |
Originally Posted by fran /img/forum/go_quote.gif I tried having a look at the pic above. I thihnk you'd need something in where C3 and C4 are, but also, it seems that you don't have anything connected to B+ terminal. Without this you won't get much sound! |
Originally Posted by fran /img/forum/go_quote.gif Down further on that tubecad page is a schematic where he tells you how to connect up the heaters in series using a 24V supply - did you see that (ie not using H+ and H- using a jumper and bringing your heater supply to each side of another jumper and reversing the polarity of one of the heater caps on each side?) |
Originally Posted by fran /img/forum/go_quote.gif He also fairly clearly states that as that circuit stands it wouldn't be suitable for headphones (hence the mention of a buffer circuit later) |
