Yes, I did that when I still had bad wires in my amp. It didn't change anything.
This time I forgot to connect XLR socket to GND-2 so I connected single ended socket to GND-2.
Also, that picture is at my house, not CanJam Dallas lol, must have pulled it from this thread for the thumbnail. I was like "hmm, I don't remember sending EL37 and ECC35 to CanJam..."
Does anybody else get a little bit of transformer hum with their unit? It's headphone out itself is dead silent, but there's a little bit of hum coming from the unit itself.
Only occasional and very quiet. I presumed there’s something on the circuit triggering it. I should really upgrade the power block.
Sometimes the VEGA G2.2 does the same but as with the Aegis you nearly have to put your ear on it to confirm the source. Lets put it this way, nothing like the hum I used to get from some Naim power supplies which could be heard a few metres away easily!
Yes, the noise sounds like 60 hz. It is not too loud (can't hear it on VC) but it can be heard with the volume all the way down.
The noise increases only when volume is over ~70% on volume pot.
Your twisted wiring looks much better, nice work. This is where things get tricky though as troubleshooting something like this remotely is challenging. Some other things that could be optimized a bit: the B+ wire from the power supply choke and the ground wire from the reservoir power supply capacitor (22uF not on the PCB) could be shortened. There looks to be some excess length from the right channel RCA to the volume pot, getting rid of the excess length may help.
But before doing those things, you may want to just reflow the solder joints for the right channel to be certain a bad joint isn't contributing to the noise. Check for loose connections in the right channel (from pot to PCB, from choke to PCB).
I think this is unlikely, but you could also try disconnecting the XLR shield from ground to be sure that isn't contributing.
