shadesbass
- Apr 27, 2006
Hi all,
I'm just about to order some expandable sleeving for a headphone recable, but the different diameters available are a little confusing and I was hoping someone could give me some tips...
I was going to use this stuff as it seems reasonably priced and is available in small quantities.
I require two different diameters, for above and below the Y-split. The cable below the Y-split is a shade under 8mm in diameter. The cable above the Y-split is constructed from 2 cores of 2mm diameter cable per side, so the diameter will be a maximum of 4mm.
The stuff I linked to above state an 'advised range of use' and a maximum diameter (e.g. PET4 = 2-7mm, max 9mm). Should I be aiming for the lower end of the advised scale, or somewhere in the middle?
I want a relatively dense braid to protect the cable (hence avoiding the upper range of specification), but not so dense as to make the cable too stiff.
Any thoughts on the matter would be gratefully received.
