elnero
No, it doesn't necessarily carry over into the headphone world.
You're speaking in pretty broad generalities. To be honest I don't have a lot of experience with subwoofers but the same rules as full range speakers should apply. Probably 90 percent or more of speakers on the market today are ported designs, going by your rationale they should all sound boomy yet that's not the case. Yes, an improperly implemented port can sound boomy but I suspect the same could be said of a sealed design as well.
When talking subs I'm going to make an assumption that a sealed box might be preferable, at least in part for placement reasons. Placing a vented design too close to wall boundaries will bring up the bass response which can result in boominess.
There's always pluses and minuses to a type of design but proper implementation both by the designer and the end user should minimize the minuses.
Given your past behavior in other IEM threads and previous comments you made regarding the SA6's I read your comments as somewhat trollish. If you are truly interested in them you might want to go to their website where they explain some of the reasons for the modular design, I'd also suggest you try them before making assumptions on their sound.
Originally Posted by jinx20001 /img/forum/go_quote.gif thanks for being straightforward. i dont know like i said i havnt listened to them. what do you think im wrong about tho? the subs? i was taught that subs are usually boomier but deeper when ported or bandpassed but still not as tight as a closed design, does this not carry over to headphone world? |
Originally Posted by jinx20001 /img/forum/go_quote.gif go easy, i wasnt saying the sa6 is bad, i was asking you guys if it is? lol i just said that in theory you would want the pros to decide what is the definitive sound, but i was asking wether the sa6 has nailed it for customisation. I mean, who needs EQ anymore if the sa6 is the new and improved |
