cms5423
- Feb 10, 2009
Hey everyone, I'm really close to making some big purchases and really would appreciate any and all advice I can get. Thanks in advance.
Path:
Macbook-->DAC-->Amp-->Ultrasone HFI-780 Headphones
(or MB-->DAC/Amp combo-->HP)
So my options are:
1)gamma-1 lite DAC (it's gamma1, just USB only)+PIMETA (build it myself): I'll only get 16bit/48kHz since it's usb only. (probably around 150$ total)--also, I've never built anything before circuitry-wise, so PIMETA would be first project, although I here it's not too difficult, but I have no soldering experience, so is this doable? Or
2)Zero DAC/AMP combo: I'll get 24bit/192kHz capabilites. Seems really well regarded, plus upgradable, but no usb input--will the digital out from my macbook mini jack sound as good as a USB connection? (150$) Or
3) DAC/AMP combo such as iBasso D2 Boa($180), Hotaudio DAC Destroyer($80) or Hifidiy Mini USB DAC (link: USB DAC+Headphone Amplifier(PCM2707+DIR9001+PCM1793) - eBay (item 300297634142 end time Mar-31-09 21:02:24 PDT)
-->What do you think is the best option?
-->What will have the best audio quality to feed into a pair of headphones?
-->As it worth it to save the 80$ and get a DAC Destroyer for 80$?
(will the DAC destroyer even improve the audio anywhere even close to the other options?)
-->And lastly, is it important to get the 24/192 capabilities? As of now I only listen to audio from iTunes, rhapsody online radio, or pandora, all of which I think are 16/48... so do I even need the 24/192 ability? what else is in 24/192 other than DVD audio?
THANKS SOOO MUCH
everyone
Side note:
I'm a college student, so budget is pretty tight. Price is important: (Cost-to-performance ratio)
Path:
So my options are:
THANKS SOOO MUCH
Side note:
