Waynester
- Sep 15, 2010
Hi Guys
i`m a newbie at all this Audio stuff
currently, my Desktop PC is this model
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01665626&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=3889579#N33
it came fitted with this internal soundcard which i`m not impressed with to be honest
http://www.realtek.com.tw/products/productsView.aspx?Langid=1&PFid=28&Level=5&Conn=4&ProdID=141
i have just ordered this USB Soundcard, is it anygood?
i will be mainly using it to listen to FLAC files from my PC
http://uk.store.creative.com/sound-blaster/sound-blaster-x-fi-hd/1-19829.aspx
i have these speakers sat waiting for connection to the new soundcard
http://uk.store.creative.com/speakers/gigaworks-t40-series-ii/4-18021.aspx
how do i connect everything up?
is it 2 phono jack cables (left and right) from the out of the soundcard
and then plug the mini stereo jack end in to the aux in on the front or rear of the speakers?
also, what is the volume dial for at the front of the soundcard?
does it turn volume up just for the headphones?
do i turn the volume dial to 3 quarters? and then turn up my speakers?
i want to make sure theirs no distortion and get the best sound from my FLAC files
will i notice a HUGE Audio quality difference with this soundcard compared to my internal one??
thanks for your help guys
