ecdarby
- Nov 19, 2014
Greetings! Im currently parts swapping through 10 or so pairs of hd-280's, mostly with one dead driver, trying to assemble as many working pairs as possible. My customer says he doesnt want to spend $30 each for factory replacement drivers, so Im looking into some more affordable offerings, just to get as many of these working again and back into use as possible.
These will be mostly used in his studio for monitoring guitar/ drum/ vocal/ etc takes during recording and not so much mixing in the control room. So, there's not really a requirement for them to sound the same as the old ones or to be exactly flat. Just trying to provide a more economic option for minimizing leftover parts and getting more studio cans back into service.
Right now, I'm most intrigued by this one, which I can't seem to find any mention of by DIY'ers. But, given the information here, do you see any reason it wouldn't work for closed backs as a retrofit into the 280's? Or is there maybe a more go to option with more documented results?
https://www.digikey.com/product-det...D45-7-32-012/2055-BFC-D45-7-32-012-ND/9842994
Datasheet: http://www.newbdnc.com/wp-content/uploads/datasheets/BFC-D45-7-32-012.pdf
Manufacturer | BDNC (HOLDING) LIMITED | |
Manufacturer Part Number | BFC-D45-7-32-012 | |
Description | SPEAKER HEADP 40MM 32OHM | |
Detailed Description | 32 Ohms General Purpose Speaker 40mW 10Hz ~ 20kHz Top Round |
