Veggomatic
Hello all, I'm on the search for some new headphones that are <$1500 that are a good fit for us large framed individuals. I recently purchased a set of LSA HP-2's that I had high hopes for but they're uncomfortable for me to wear. The auto adjusting headband maxes out once I get the pads on my ears, and then my right ear is larger than my left and the pad either squishes my earlobe or the top of my ear. For reference, my head is 24 5/8" (roughly 63cm) which puts it typically in the XXL size for things like hats/caps.
My job has moved to 100% from home permanently, so I use the headphones for probably 6 hours a day for both music and video calls and I'm looking to upgrade. I'm open to either open or closed back, though I tend to prefer headphones with a decent amount of bass output and prefer a fun signature over analytical sound signature, though I know the term "fun" is subjective. My currently daily headphones are Shure SRH1540 and I'll occasionally pop in my Shure SE846 IEM's. The shortcomings of the SRH1540 for me are soundstage and separation, plus the top end is a bit muddied compared to some other headphones I've enjoyed.
My current equipment setup is a Monolith Liquid Platinum amp, being fed by either a Topping D90SE or a Denafrips Ares II. I'm trying to figure out which DAC I'll keep and it comes down to what headphones I end up with. I also have a Matrix Audio Mini-i Pro 3, but it's overkill for a bedside setup and will likely be selling it.
Any and all input is greatly appreciated, thanks.
