hardbop
- Feb 16, 2005
I'm in search of a great headphone solution.
I only have the SR-60's and classic Airhead amp. Great stuff for rock music. Unfortunately, the headphones are out of commission (they have been for awhile) and I can't get them fixed for another month.
I'm in need of a headphone that excels with classical, jazz and acoustic guitar. The whole setup needs to be portable, because I will be using them at home and work. Since I work alone, leakage isn't a real concern.
I've been researching this for the past few months, but I'm still unsure which can or amp will best fit the bill. Since I don't have access to any high-end phones locally, I'll probably end up trying them out one by one via Headroom. There aren't any stores in Houston that cater to audiophiles, are there?
On my list to try is:
Sennheiser HD-595 and HD-600
Etymotic Research ER-4S
Beyerdynamic DT880
AKG K 501
As for amps, I'd like to try the new Supermacro or the SR-71. I'm also leaning toward the Total Bithead, particularly for the convenience of a USB connection, which would allow me to enjoy music on my home computer and save batteries while at work.
I'll need a headphone bag, too. The Headcase from Headroom looks like it would work well.
So what I need from you guys is input on which setup might fit my listening tastes, especially for classical, and how best to go about finding the best match. My budget is about 500-600 bucks max and my musical source will by my iPod and my computer. I'm looking foward to the education and experience in hi-fi headphones.
Beyerdynamic DT880
AKG K 501
