lewis82
- Jan 9, 2010
Hi,
After having used only cheap earbuds for years, I decided to take a step into sound quality and purchase IEMs. They will be used to listen primarily to prog metal, but also some rock, "classic" metal and jazz.
That would mean: not too much bass. More bass over the earbuds would sure be appreciated, but I'm not listening to techno/hip-hop. I would prefer something very balanced, with good output in all ranges.
So I have narrowed my choice to 7 models:
The common point is, they are all below 120$.
I was really considering to buy the Kilpsch Image S4, but according to you, are there any models which would be better?
- Klipsch Image S4, which are the ones I'm the most interested to due to good reviews
- Shure SE115 and SE210 (but I heard they are too bassy)
- Ultimate Ears SuperFi3 and SuperFi4
- Etymotic Research eR6i and hF5 (altough the triple flange doesn't seem very comfortable)
