precsmo
- Dec 7, 2006
Hi to all gurus, I'm using the left, right and ground channels with AD843JN in my Pimeta, it seems works fine and it sounds great! But after 2 to 3 minutes, these opamps tend to get really hot! please advice what to do. Here are my settings:
Thread (test and seems works fine):
-Tuned to 28V (to Pimeta +/-14V), I've tried lower it down to 24V, but no difference
Pimeta:
-left, right and ground channels all with AD843
-gain set to default, Gain 11, as in TangentSoft's diagram where:
-R3 is 10k, R5 is 3.32K, R6 is 1M and R4 is 10k
-all 4 power rails capacitors of 1200µF 35V, I ordered it wrongly instead the 1000µF 35V (should I change it back to 1000µF as recommended default maximum in TangentSoft)?
-all buffers are 2 stacks, though the R11 for left and right channel buffers I used were 100Ω, the ground channel was 200Ω as I miss ordered it and will replace it soon, does this affect anything?
-volume control I used 50k ALPS RK27
-the rest I used as recommended default in TangentSoft
My another experience, I find Gain 11 is more than enough for my HD580, should I reduced the gain, is the gain directly affects the opamps from heating up? I really enjoy the sound, but I can't feel safe to run the amp before I can stop the Opamps keep heating up badly, please help! Thanks a thousand in advanced! I tried to search everywhere, but can find much about AD843 settings.
Pimeta:
