breez
- Jun 6, 2004
Does anyone know how the AD823 (or a similar op-amp) performs with a low impedance load with the minimum supply voltage (+3V)? The internal amp in iRiver H120 doesn't seem to like 16 ohm E2Cs and starts distorting even at sane listening levels (THD ~0.4%, but with a not-so-nice spectrum).
I want practically no bulk added to my portable "rig", so my idea is to build a very minimal amp with no volume control, supply from the DAP (+3V available) etc. and packed very tight. The focus wouldn't really be sound quality, but size and trying to overcome the deficiencies of the iRiver amp (it and the line-out are just fine at driving line level impedances). Is there any point in this?
Another (simpler) idea is to add some resistance in line with the iRiver output and make the amp see a lighter load. But what does it really help? To get the same SPL to the Shures I need to increase the volume and the same amount of current will flow than before.
