Syzygies
- Nov 16, 2004
I raised this question first in PPA v2 Project Announcement, in reply to PPL's post The PPA 2.0 Buffer tech info. I did not intend my question to be a suggestion for revising the PPA, whose design I intensely admire, and whose size would not accommodate my idea. So I'm moving my question here.
Given enough board space to accommodate the experiment, would it make sense to incorporate three diamond buffers into the power supply stage of a headphone amp, in addition to using three diamond buffers for the output stage?
We are familiar with op amp stages without buffers (CMoy), and op amp stages that incorporate buffers (Jung multiloop topology). We are familiar with power supply stages without buffers. Stop reading for the moment, and decide how you would fill in this remaining square in the chart: design for yourself a power supply stage that incorporates buffers.
I was thinking of starting with wide rails, e.g. an 18 volts or higher battery of NiMh cells, and using voltage references to somehow derive +2, +9, +16 as the three equally spaced voltages of a V-, G, V+ virtual ground scheme. Now use these references as the input signals to three diamond buffers, powered by the original 18 volt rails. Use the output of these three buffers as my power supply for the later stages of the amp, i.e. the next three diamond buffers have L, G, R as inputs, and the V-, V+ from the power supply buffer outputs as their rails.
I understand that op amps and buffers have pretty good power supply rejection ratios, which is why sagging rails under buffer load don't affect the sound that much. On the other hand, there's got to be a reason why people want to pay good money for Black Gate power caps, or build themselves massive, "stiff" power supplies. I can only conclude that the quality of the power supply does somewhat matter. It would seem to me that a well-designed active power supply could outperform a passive power supply.
Sorry, I was replying to the general potential of your new diamond buffer design, I did not intend my suggestion to be directed to the PPA v2, which I see as a showcase for this buffer, but by no means its only application.
Do you think my idea would work?
Originally Posted by ppl Syzygies> the concepts you talk about while conceptually intriguing are not applicable for the small form factor of the PPA. Please remember that this is a portable Amp and space is limited. I cannot imagine where you’re going to put 3 more buffers at on the ppa board. I believe that with the power supply rejection ratio provided by the ground channel and the Jfet rail isolation network. I cannot see how you consider that we addressed this issue with massive capacitance since the PPA actually use substantially smaller capacitance that other premium Amps. However thanks for taking the time to look into this and comment upon it for us hear. |
