Hello.
Yesterday I got angry because I started hearing weird noises from my DT 770 (ed. 2005 600 ohm)'s left phone when loud deep bass was present in a track. So I took the left can apart and while doing so I accidentally pierced the dampening paper on the ring around the driver with my screwdriver. Does anyone know whether this will affect the sound? I pierced only one layer, the one closer to the ear. The hole is about 2 x 3 mm large and about 1 cm from the outer edge of the driver unit. Better yet, I did not find the cause for the rattling cause by bass sounds.
When I listen to them I do not notice any difference in sound. Does anyone know if and how will the hole in the dampening paper affect the sound?
Thanks.
Thanks.
