tomb
Member of the Trade: Beezar.com
- Mar 1, 2006
This is up to the OP, but I think this thread got quickly off-track.
When faced with audio components, having the transformer outside of the audio device internals is always best.
That's because removing the noise from the AC-portion of the circuit is one of the primary goals in audio component design. Put a transformer in the same box as the rest of the audio and you may forever find yourself trying to eliminate hum. So why do people ever put the transformer into an audio cabinet? Because, not every voltage and power rating is available as a ready-made wall adapter or separate power supply. Also, for very involved audio devices, building a separate power supply can be a PITA for the end user. I'm not saying that people don't do it - there are some very, very nice audio components available that use an entirely separate power supply cabinet. However, it's still a hassle to the end user. The umbilical is often specially-made, the secondary cabinet can be quite heavy and it simply becomes very inconvenient to place and house the equipment in a home environment.
In the case of smaller, lower-power devices, the DC voltage required may be readily available with a wall adapter. Thus, it becomes a no-brainer to design the device to utilize such a device. It would even be much more expensive and impractical to locate a transformer inside such a box as the Schiit Magni.
If different voltages are needed for the same device, or as stated earlier - the voltage and power ratings are not readily available in a cheap wall adapter, then the other option is locating the transformers inside the same cabinet. In this case, placement and type of transformer can be very important, so as to minimize the potential for hum. This can be successfully done with a good design however, and the result is a single, unified casework device with only an AC cord used to plug the device in. The convenience is much better for the customer. When you are considering DACs, very often multiple voltages are needed for many separate sections. Separate wall adapters would be almost impossible and a separate custom power supply with umbilical also becomes impractical.
BTW, I'm not sure that the transformer type is really that important - assuming the hum is removed through proper placement - as long as the voltage and power rating is sufficient. However, there's a lot more that goes into making an audio-quality power supply than just the transformer and its rectification. You can still produce ripple or any number or distortion components if the power supply is not rigorous enough.
