artazzzzzz
- Aug 21, 2010
hello,
As far as I know bit rate = sample rate x bit depth x number of channels.
For example a CD quality song which is 16 bit depth would be at 44,100 khz x 16 bits x 2 channels (stereo) = 1411200 bits or 1378 kbps bit rate. That means a lossless song in WAV format should be at 1378 bit rate or a little bit less in FLAC. Now if you convert lossless quality song which was recorded at 16 bit depth to MP3 (let's say 320 bit rate VBR) its bit depth automatically drops as number of channels and sample rate remain the same.
There are MP3 decoders that offers 8/16/24/32 MP3 decoding.
My questions are:
1. What those decoders actually do?
2. How is it possible to decode MP3 song in 16 bit and higher quality as an MP3 song is usually lower than 16 bit depth?
3. I've heard about accuracy of decoding, will an accurate decoder give me better quality?
Thanks
My questions are:
Thanks
