Centinul
- Nov 17, 2005
Well I would like to build an A47 amp and I'm having trouble putting a parts list together. I'm probably going to order from www.digikey.com. Here are the parts that I THINK I NEED SO FAR, as mentioned in the following A47 Instruction set:
A47 Instruction and Layout
Code:
From the schematic of the A47 I still need 470 microF capacitors, a "D1 1N5822" and "P1a 10k". I don't know which type of capacitors I need. I tried looking through the Digikey.com website and there are so many different capacitors to choose from, and I don't know which kind I need. Also I don't know what a "D1 1n5822" is and I do don't recognize the symbol. The "P1a 10k" looks like a variable resistor but again I don't know which one I should choose so please let me know.
I would like to get started on this project and I just want to make sure I have the right parts. Please any help is appreciated.
Code:
Code:
[left]Capacitors 2 565-1610-NDCAP 470UF 50V ELECT KY RAD $1.04 2 495-1086-NDCAP .47UF 50V METAL POLY $0.64 2 495-1087-NDCAP 1.0UF 50V METAL POLY $0.82 *In case I ever want to tweak the bass* Resistors 1 P2U4103-NDPOT 10K OHM 12MM HORZ MET BUSHIN$2.66 5 2.49KXBK-NDRES 2.49K OHM 1/4W 1% METAL FILM $0.54 *Gain to 5* 5 4.75KXBK-NDRES 4.75K OHM 1/4W 1% METAL FILM $0.54 *Gain to 3* 5 47.5XBK-NDRES 47.5 OHM 1/4W 1% METAL FILM $0.54 5 100KXBKRES 100K OHM 1/4W 1% METAL FILM $0.54 ICs\Transistors 2 1N5822DICT-NDDIODE SCHOTTKY 40V 3A DO-201AD $1.36 1 BUF634T-NDIC 250MA HS BUFFER TO-220-5 $8.10 1 296-1994-NDIC 1/2 RAIL VIRTUAL GND TO-92 $1.30 2 OPA2227PA-NDIC DUAL PRECISION OPAMP 8-DIP $7.92 2 AD823AN-ND IC OPAMP FET DUAL 16MHZ R-R 8DIP $10.00 1 HLMP1790-NDLED SS GRN DIFF LO CURR PCB 3MM $0.34 Misc 2 BH9V-W-ND HOLDER BATTERY 9V WIRE LEADS 0 0.88000 $1.76 3 CP-3535NG-ND CONN AUDIO JACK 3.5MM STEREO 0 1.01000 $3.03 1 360-1155 SWITCH TOGGLE SPDT 6A 0 4.20000 $4.20 2 AE7313 IC SOCKET .300 8 DIP GOLD 0 0.93000 $1.86[/left]
