tiagoncalves
- Mar 26, 2012
I finally received all the parts, and yesterday I finished the A47 amp, using the next schematic, but with a 1,8 kohm resistor in R2 (instead of the 4,7 kohm):
Unfortunatly, I have a lot of distortion, and the DC offset is very high: 150 and 90 mV in each of the channels. What tests can I perform, to check the origin of this offset?
Can i try to remove the input caps to see if they are the problem, or can I make some tests to the opamps?
The opamp before the buffer is the same as the other two (opa2132), but I just used one of the channels.
Thanks.
Thanks.
