mbayaq
- Oct 13, 2004
I just picked up a pair of KRK Rokit 5's (I know, they arent headphones, but my question relates to preamp type stuff
). Basically, they have no volume control other than the gain adjustment on the back. I need to be able to adjust the volume, and the only way I have been able to so far is by using the windows control panel and adjusting the main volume by mouse..... and it really sucks.
I would like something to basically do what this does, the Mackie Big Knob, though I only really need volume control and input selection is optional. I also don't want to pay a lot for it, preferably under $20.
I found another option, the Griffin Powermate, which is a USB knob that adjusts the control panel volume or whatever I want it to. This, unfortunately, costs $40-$50. I would really like to be able to adjust the volume without paying more than the cost of my sound card to do so.
I'm also very open to DIY ideas, such as buying a pot and putting in a box with two 1/8" jacks on it or something, but I'm not sure what pots would be worth getting, or even if this is the best option. I'm open to any and all ideas and suggestions. Thanks in advance for your help.
