I'm neutral in the power cord wars, but I don't see how this argument makes sense. If we assume that the solid core wiring in the walls is better, and if what we're really trying to do is reach its level of performance, couldn't "audiophile" power cords just be made out of the same solid core wiring? That stuff is dirt cheap at Home Depot. |
Problem is again flex. Solid 12AWG needs to be shaped. Care to hazard a guess as to what those super thick, incredibly unflexible PCs some people pay hundreds of dollars for are made of |
Pretty much that is it nailed.Using standard building grade Romex wire would make a superior AC cord but this is about the least "user freindly" cordagwe on the planet.I have wire many houses from the service box out and the way this is done is by leaving the spool at the AC service entry point where the breaker panel is/will be then snaking it through the floors and walls.Each one of these direct lines is called a "home run" with
Home being the panel.By being directly connected with nothing in between this line is as
clean as it will get until you begin to "daisy-chain" additional runs off this main line so a smart person would use one of these for each computer area and each audio/video are and have nothing else on that line and by nothing i mean not even any additional wall outlest not meant for the use intended.
But I gotta tell you folks,pulling this wire through holes in the frraming is no picknick and if you do not have hand strength or a partner feeding stay your behind at home ! Inflaxable and non co-operative as any wire on the planet and even worse than BX-armoured wire !
Imagine having this butt ugly wire hanging off the back off your gear sticking straight back and then down unless you
physically force and gentle bend in it just to get it to look semi good.
and forget about expecting it to lie flat on your floors.not going to happen unless you nail it down !
So that is in a nutshell why consumer equipment uses different cables.no matter how good or how bad a thing is it must work and not be a problem in the avergae home used by the average human so multistrand cable was invented.EVERY after market cable is just an attempt to get the multistrand geometry to act as good as the solid conductor wire in your walls.
A possible comprimise is to strip out the three conductors from the romex and do either a three cable braid (a real bitch on the hands !),use cable ties spaced 12 inches apart to keep the three strands together or even leave the three strands "loose" with the plug ends providing cable integrity.This cable will STILL not lay flat on your floor for long runs and will still be stiffer by fat than any stranded AC cord but is at least a workable solution if you must try it.
Bare Naked Romex will also look way better than romex dressed inthe ugly white wrapper though i guess you could run a cover of some kind over it to "pretty it up" a bit.
Option # 2 :Break out the three strands (still a real bitch unless you have the right tools,trust me on this one
) then take the "hot" and "Nuetral" wires and twist them together.cover this with PVC tubing or techflex and attach high grade
two phase plugs at the ends.Next take the green ground wire and to the two ends attach a NEMA rated ground lug spade connector.Take this "mini-ground-wire-assembly" and wrap it around the outside of the hot/nuetral wire pair so that you have the hot/nuetral with plugs and the ground with spades.
You now have total control over system ground.By attaching on end of the spade assembly to a chassis mounted screw on your equipement and the other end to the screw on the wall plate you have your earth ground connection back but now
you have
total control over your system grounds.
If you have a ground loop induced system hum simply lift one end (remove the sapde connection) to break the ground loop.I don't recommend removing the safety ground but this is a good test that will tell you what you need to do somehwere else to eliminate the problem.
You also now have the ability to whip up a dedicated earth ground system strictly for your AV system by having an entirely seprate run from outside (the in ground bar),up the side of the house,into the wall as you would a cable TV or SATV cable then to a dedicated ground block which then distributes the ground to each componant.Sounds difficult but actually a real cakewalk
the real beauty is you can scrap the ground wires and replace them with either longer or shorter ones without scrapping the entire cable and by being the same wire as is used to wire your entire house you have just eliminated a potential "bottleneck" that by being the weak link
could starve your sytem current delivery for peak dynamic events.
Remeber,during these peak events every single part of the signal chain is ramping up at the same time and if the system is unable to deliver pure kill power (think V-8 engine) then one sections power supply will steal from another in the attempt to reproduce the power it needs.this in effect is system compression and that is never a good thing
YMMV of course.Just my 0.0002 centavos
