A TREAD sized regulator - the r1
Jul 7, 2012 at 10:53 AM Post #167 of 189
Looks like I blew the build, guys.
   I got R6 and R7 correct, but I neglected to order the correct versions for D1 and U2 at 24V output.  I can't get any more than ~8.6VDC on the output and I don't have a load that low to test.
I'll have the right parts on order today.
May 18, 2013 at 11:35 PM Post #168 of 189
What ever happened to this project?
May 19, 2013 at 12:23 PM Post #169 of 189
Umm ... unfortunately, it's in my lap.  I built one for the purpose of making specific measurements using Tangent's LNMP.  However, my LNMP batteries shorted out, made a mess and blew up the TLE chip.  Dsavitsk fixed it for me, since I was pretty busy at the time, but then I blew out the r1 I built.  (I put too much voltage and current load on it.)  I have all the parts to build a new one, but just haven't got 'round to it, yet.
May 19, 2013 at 5:02 PM Post #170 of 189
Does this mean you now know what maximum voltage and current it can feed? I'd be interested in those numbers.
May 19, 2013 at 8:37 PM Post #171 of 189
Just going from memory, but I think cobaltmute indicated that there's no problem exceeding what I did - it's just that the parts selection at present was not set up for that much.
May 20, 2013 at 1:58 AM Post #172 of 189
I have a few projects that would benefit from a board like this. I'm thinking of going with a Salas v1.1 BiB which might be overkill. Or a Sigma 25, which might be in the same league. I like that the size is super small and flexible.
May 22, 2013 at 10:45 AM Post #174 of 189
I'll admit to not having looked at the circuit in quite a while so it would take me a few moments to figure out the limits with the "default" BOM we spec'ed. That doesn't mean that you can't spec out a different set of parts to meet a specific need. With the proper choices for parts (and heat-sinking), the practical limit will be the copper traces on the board.
May 29, 2013 at 4:08 PM Post #175 of 189
What a fascinating thread. I just read through the whole thing. I probably understood 2% of it, but it was great to see how the project developed. It's too bad it's been languishing a bit, however...
Question: would it be feasible to build several of these to use as bench power supplies? Maybe a 3V, a 5V, a 6V and a 12V? Other than continually adjustable voltage, what would the benefit of a bench power supply be?
Best regards,
Adam
Aug 25, 2013 at 8:32 PM Post #177 of 189
Is this project officially dead? I'm looking for a small, low-cost 6.3V power supply and I thought this might be perfect, but...
No, it's not dead - just in suspended animation because of me.  I'll try to do better.
Aug 25, 2013 at 8:51 PM Post #178 of 189
Not trying to pressure anyone - you don't owe me anything and if this ever comes to fruition, I'll be grateful for the work you and everyone else has done. Thanks for the update -- glad to hear it isn't dead!
