va3ttn
- Nov 13, 2008
At the moment I feel much more comfortable with wavelengths
measured in meters, rather than in millimeters
10 kHz measurements are 1000 times more difficult than 10 Hz measurements
because the wavelength is 1000 times shorter.
Everything is much simpler when the wavelength is much longer than earpad and ear dimensions.
There are no resonances due to reflections and the sound pressure
is much more uniform in space, making microphone placement much less critical.
As said above, I'd like to perfect low frequency measurements
before I even attempt higher frequencies.
Originally Posted by Fitz /img/forum/go_quote.gif I'm not sure why you're so against measuring a full sweep of the frequency response? |
