StarTreker
- Jul 25, 2016
Those who know me here know that I recently bought a sweet pair of JVC headphones, along with a Fiio amp to power them. I've been listening to them through my computer and have been running on a corrupted Windows OS for the better part of a year. I tried to fix my Windows installation with a re-install, but because my computer is a notebook, it requires special drivers at setup, and apparently in Windows 7 time period, Microsoft couldn't figure out how to put them drivers on their install, so I had no way of acquiring them for setup so a reinstall was bust.
After so many BSOD's, exceptions, program hangs and crashes I said, thats it! I switched to Linux people, yes you hear me right, I left Windows for Linux, specifically Zorin Linux lol. So far Linux has been a far improvement to system stability, however, it lacks certain components in which we all take for granted on windows, like a system wide equalizer that can adjust frequencies globally, so you don't have to have equalizer plugins for every single program, in which you want to change the sound on.
I discovered PulseAudio, but trust me you don't want that. It might be a linux based system wide equalizer, but as soon as you raise any of the frequency sliders, you get really bad distortion. And I think this is because PulseAudio tends to raise the gain volume along with the frequency, and without a preamp/gain slider that you can drop down, the software is useless. So if you've switched to Linux like I did and are pulling your hair out wishing you hadn't now, maybe this solution can be the answer for you.
Currently, my setup is like this. Notebook connected to TV via HDMI, audio is patched through HDMI. Audio comes out of TV through a optical digital cable into a Fiio DAC, which converts the digital signal to RCA anolog. RCA connects from the converter to my speaker system, and my headphone are plugged into the speaker system headphone jack, which is then patched through my Fiio Amp, and then my headphones plug into the amp. I know, thats a big setup, but all cables are high end, so quality degradation in sound is not an issue.
What you want to do is get yourself an external equalizer, and you want one with at least 10 bands or more. Getting those brand new today will cost you several hundred dollars, so its better to buy one used. And even better to buy one used that is Vintage made in Japan, which is of a higher quality then most electronics you can buy today! I just ordered the Realistic 31-2010 12 band equalizer off of ebay for 45 bucks, which is a steal because I am sure the unit cost 300 when it was new back in the day. I also purchased a 6 foot high end RCA Monoprice cable.
If you have a setup anything at all similar to mine, then what you want to do is run a RCA cable from the output of your DAC converter box, to the equalizer's input on the back. Then run another RCA cable from the equalizer's output connection, to your speaker system's input. You might be wondering why I am going through such a long path for my audio setup just for my notebook. Well, by connecting it up this way through the TV's audio output, it allows me to not only equalize the sound from my computer, but my Xbox360, my blueray player, and my tablet. As I have all those audio sources patched into the TV. So it just makes logical sense to set it up that way, so I can equalize any source coming through the TV's output.
I can't wait till my equalizer gets here, I really need to get my sound enhanced! lol
