foobar2015
- Dec 7, 2015
I don't want to buy an expensive external DAC to replace my Marantz AV receiver. I have a computer, which should convert any lossless audio format to PCM by software easily.
So I have an idea to build bit perfect network connected devices that streams PCM from PC USB port to my AV receiver HDMI port. I will post my DIY log. Please let me know if you have any idea or comments.
DIY Log
Dec 26, 2015
My first step is to capture PCM from PC. One of easy solutions is to build a DAC to capture PCM and then streaming PCM over network. There may be an alternative easy way to use ALSA API to create a virtual sound cards. But it is not portable to Windows and Mac. I do have Mac and Windows at home beside Linux.
On the other hand, using USB DAC is a hassle free solution. UAC2 device is plug and play in Linux and Mac. But it requires more software work. After some researching, I decide to reuse my odroid U2 arm board with USB OTG port and make it a USB DAC.
Dec 28, 2015
After two days hacking, I managed to aplay PCM from host PC and listen sound from odroid u2 board. Although the tempo doesn't sound right, this is a great step. I will investigate more. It should be an issue in f_uac2 code.
[To be continue]
DIY Log
Dec 26, 2015
Dec 28, 2015
[To be continue]
