I personally would not upgrade from the HD 558 to the HD 598. Even though I favor it more, the difference is too small to consider purchasing. You may even consider using both as a bonus, since the HD 558 has a bit more bass than the HD 598 so it sounds better with electronic music. You can use your HD 558 for more bassy music, while use the HD 598 for everything else. That being said, since you ordered it, there's almost no going back, unless you plan on returning them, in which you should consider a sidegrade rather.
A non-sense probably - From Sennheiser 558 HD to 598 HD
- Thread starter daniel0407
- Tags
- sennheiser-hd-558
