jcx
- Jul 24, 2002
you are free to put the little gnd triangle on any (one) node in a circuit and it will (except in sims with the flawed macromodel issue) behave exactly the same - all "V" readings in a real circuit are V difference readings - and you can choose your reference in any way that aids understanding
a convenient location for the Spice node 0 gnd symbol in active supply split circuits is the output of the supply splitter
in LtSpice you can make difference measurements explicit by holding down the button when selecting a circuit node for display and draging the probe to any node you wish to use as reference - the probe symbol will change from red to black and select the reference node when you release the button - the trace in the waveform viewer will have a label like: V(n003,n007) indicating it is an explicit difference; the reference is not displayed when it is referenced to Spice node 0 = gnd
