comiconart
Great, thanks - good to know! Would the NAD 7140 be considered “vintage” in this respect..? Late 80s, so not sure where it falls
I just re-read your first post where you say:
Does your turntable have RCA outs or just USB? If it has RCA you need not worry about the phono stage of the receiver. It should work fine going into the AUX input of any receiver,assuming again that it has RCA outs.
Nah...you want the silver faced pre-1980s era gear...After that you get into the BPC(black plastic crap) era.
From your previous post: would the NAD 7140 be considered “vintage” in this sense (good headphone jack and true stereo sound, etc)? Late 80s, so not sure if that qualifies...or if I should be looking to a 70s Marantz instead, etc
This is daunting.
I will say that, generally, the phono preamps in older vintage receivers are going to knock the socks off of integrated units in the turntable. The receiver will be able to handle the speakers (probably), the headphones (probably, though accounting for output impedance can be tricky), and act as your phono preamp, which is ideal, if you have the space. Worst case scenario, you get something like the PS Sprout, if you want an integrated unit. Buying separately isn't an awful idea either, but it does require keeping track of more stuff during the purchasing process.
I have bias toward 70s era Marantz and MAC units. I've personally recapped dozens of older Marantz receivers, and I think they sound great. A lot of it depends on the sound you're chasing though. Like was mentioned earlier, the Sansui's can be a bit warm, and I generally prefer neutral with a slight warmth. The Sansui 5000 was too warm for me.
If you haven't already gotten your speakers yet, I could recommend some cheap Dayton or Klipsch bookshelf speakers if they're used in a Nearfield setup. If you need to fill a larger space with volume, that may change things.
I can get speaker stands and position them away from the wall if this is necessary for optimal sound. Just tell me what I need to do and I'll do it.
Finally, in terms of setup: This is going in a large(ish) basement office area - the room is rougly 15" x 30", and the stereo will be set up on one of the short walls, facing my desk which is at the other end of the room. I can get speaker stands and position them away from the wall if this is necessary for optimal sound. Just tell me what I need to do and I'll do it.
Your ELACs have a front firing bass port so no need to move them away from the wall,though you can if you wish.Heck you can even mount them to the wall if need be.
15" x 30"? Or 15' x 30'?
