fishtankfish
- May 9, 2005
I'm new with iTunes, I've been using foobar but I've started to mess with iTunes and am having complications. I'm not sure if these are common problems or not.
1. Is there a way to move the album art box?
2. When I change tag info in iTunes what tag is updating b/c it doesnt seem to be the ID3v2 or ID3v1?
3. When I added my music folder as the library some files just don't show up. i.e. I have almost every Beatles album on my pc at the moment. In iTunes only three albums showed up and then a couple random tracks from Revolver and Sgt. Peppers. Also, an entire Azure Ray album doesn't show up even when I add it manually. Yes, they are all mp3s.
4. When I delete and/or move a file/folder from my library folder is there a way for iTunes to automatically remove it from the library without me having to remove it manually? When I go to the play the file that has been moved it just says it can't be found, is there a way for iTunes to remove it automatically?
Thanks if you can help me with any of these.
